DENON - A2802 -3802 -reliability issue
Discussion in 'AV Receivers & Amplifiers' started by smit, Mar 8, 2002.
Tags:
  1. smit
    smit
    Recently I went the Service center of DEnon and Yamaha.
    There there were 10 - Av2802, 3 -3802 ,4- 1802 , As B- GRADE for Repairs.
    To me that shows that there might be some reliability issue.
    Does anybody have this problem?
    When one spends money just for an AV/AMp -above £350. , I
    believe should get a good reliable unit. - : which for some people a haeart of their system.
    smit
  2. gazzerr
    gazzerr
    Aug 29, 2001
    180
    16
    Damascus
    Smit,
    Had my 3802 for 3 months now and no problems so far, except how to fit that stupid FM aerial that they supplied;)
  3. Jase
    Jase
    Mar 16, 2001
    10,803
    United Kingdom
    +2,693
    You dont come across many that have problems though theres bound to be some faulty units considering the number they sell would be fairly large.
  4. Skid Solo
    Skid Solo
    Nov 13, 2001
    105
    Hertfordshire
    No problems with my 3802, had it 3 months now
  5. Whatts
    Whatts
    3 months and no problems with my 3802.
    I agree with Jase on this one...
    - Tom -
  6. DRC
    DRC
    gazzerr
    You almost have the same congig as I will have, when the gold amp get in.
    What do you think of the MA + Denon.
    I have the 8i 10i +fxi
    How long did you run them in for.
    What cables did you use.
    Anything in the step up I should take note of?
  7. gazzerr
    gazzerr
    Aug 29, 2001
    180
    16
    Damascus
    DRC,
    I think I must have been one of the first to get the 3802 from the first batch of Hi Fi Junkies stock but then had to wait for it to get across the channel.
    I have got mountain snow silver cable wich is similar to QED Silver anniversary ( so I'm told) with QED airloc plugs. I have bi-wired the front three with normal for the back speakers.
    I didn't do anything special about the running in and like PC says on the M&K thread the speakers just sound better each time you use them. Of course I can't be sure that they are changing it might just be that I am getting used to them. I was a bit concerned at first that the "brightness"" issue was there but as I have used them more it hasn't been a problem.
    I messed about with Spikes and stuffing sponges in the back but I couldn't hear any difference even when I turned my hearing aid to full volume ;)
    I still haven't tried the mass loading but one day when I'm bored I will give it a go.
    Good Luck with your set up, let me know what you think.
    Cheers:)
