Denon A1SE/3805
Discussion in 'AV Receivers & Amplifiers' started by danfrance110, Sep 14, 2004.
Tags:
  1. danfrance110
    danfrance110
    In the middle of upgrading my whole system and have around £900 for a new receiver. I was originally looking at the Denon 3805/ Yamaha 2400 or Pioneer AX5i but a friend of a friend has offered me a mint Denon A1SE for around my budget £900. Is this a good deal? Its going to be driving Gallo 'A' Diva and micro's. Also, will be buying a plasma shortly, will there be lip sync issues with the A1SE?
    Dan
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    In my opinion that price is probably about par for the course , no super deal.
    The Denon isn't going to cause the lipsync problem , video processing by the plasma (deintrelacer/scaler if you have one) will do that. The problem with the A1SE is that I don't think it has master audio delay (unless it has has the KAVCA1SE upgrade) should you have lipsync problems. The 3805 & AX5i definitely do have this feature.
  3. danfrance110
    danfrance110
    Well I can pick the A1se up for £800 which I thought was a good deal? Do all plasmas suffer lip sync? Will it not be superior in sound quality to the AX5i and 3805?
  4. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    I would have thought the A1se would have been the better option. Also you can get it upgraded which might help too.
