Denon A11SR HELP!
Discussion in 'AV Receivers & Amplifiers' started by akash, Feb 19, 2002.
Tags:
  1. akash
    akash
    Feb 15, 2002
    90
    London
    hi does anyone know how to utilise the seventh amplifier which is normally used for surround back (there are 2 surround back amplifiers. ie 2 rear centre channels; i only use 1)
    I want to use the seventh unused amplifier's L & R output to drive my front amplifier's HF frequency ouput and the main L & R channel outputs for the LW frequency.
    apparently the denon av4802, which is the american version of the a11sr has an option menu to use this.
    thanks for help
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,493
    United Kingdom
    +2,030
    What you´re refering to is the Power Amp Assignment which lets you have 5.1 in one room and power another set of speakers (connected to the relevant multiroom terminals on the back of the amp) in another room.
    Its not possible to do what you want, you would need a seperate power amp and would have it connected to the main speaker pre-outs.
    I see what you´re thinking but its not possible.
    cheers
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I think it's not possible anyhow since you have only one spare amplifier, but to bi-amp (that's what it's called) you would need 2+2 amplifiers, not only 2+1.
    BTW: If one surround back output has two terminals (L&R) each I would actually be very surprised.
    Jase, couldn't you (if you have both amplifiers unused) assign them as described and select the same source for the multizone output, thus "tricking" the amp into a bi-amping mode for the fronts? Of course the fronts need to be wired accordingly ...
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,493
    United Kingdom
    +2,030
    Reiner
    The power amp assignment on the Denon assigns the amps of the Surround Back speaker terminals to power EX/ES or multiroom(You use the same terminals).
    Not sure about "tricking" the amp as you suggest though. Worth trying, cant do it on my A1SE as Ive got no power amp assignment!:(
    Might give it a go on my Dad´s 3801 (not sure he´ll want me playing about though so dont hold your breath!!)
  5. jignacio
    jignacio
    In orther to bi-amp the front speakers using the A11SR:
    1) I need an stereo power amp or an integrated amp?
    2) how to connect the seperate amp and how to config the A11SR
    Thanks for help.
