JL12W7
Hello
I am in a bit of a bind or a confused place I was going to buy the Yamaha RX A8A but that will be out of stock for the forceable future so Have decided on the Denon AVC X 8500HA or the Anniversary A110 both of which are in stock depending on which one I plumb for.
Reason for a such a jump concerning both AV amps is the fact this AV Amp will be a keeper by that I mean I will keep it until I am forced to change due to a new av plug comes out which more than likely wont be for a very long time so I am looking at a long term usage, the 6 years warranty helps and supposed better internal components so it is bound to have better innards over the standard 8500 has anyone purchased this A110 as I have read the ones that have are more than happy with it.
What I would like to ask is the A110 worth buying over the standard AVC X 8500HA. As the Anniversary model has dropped £1100 does anyone agree there could be another price drop should I wait. I assume Denon would just pull stock and not reduce further as that would water the price down for those who paid 5K and that would upset a lot of those who paid full whack At time of release.
I need some advice do the great majority of you agree the A110 is not necessarily worth the extra money as the reviews state they could not tell the difference between the standard 8500 over this A110. A lot of places are reducing this AV amp so that tells me a new model must be imminent.
I just don’t want to be spending roughly another 1.6K for the anniversary model if I am not really going to benefit from buying the this model over the bog standard as I really don’t know myself I am just looking to gauge the reaction here on the forums to see if I have made the right decision..
Advice needed.
Advice needed.
