Denon A11 Audio Output
rosemanbridge
I am setting up my A11, is it preferable to connect the Digital Audio Output using the Optical or Coaxial Connector? What's the difference? Thanks.
Jase
Try either/or. Do a search on optical vs coaxial and you'll find loads of threads, usually ending up in arguments as to which is best. Give them both a go and make your own mind up. :)
🎬 The Creator & Reptile, Guardians 3, The Others & Cutthroat Island 4K & Best/Worst Renny Harlin
Back
