Denon A1 component configuration?
Discussion in 'Blu-ray & DVD Players & Recorders' started by IanW, Dec 3, 2003.
  1. IanW
    IanW
    Feb 28, 2001
    1,585
    Wiltshire
    +145
    Got my Domino 20 this weekend and is now all setup and working. :clap:
    Can someone please confirm the following and if possible explain why?
    Having previously had the A1 connected to my TV via scart, the AV1 output was set to RGB. When I connected the player to the Domino 20 the projector was using CrCbY 32khz but would freeze from time to time. Could not get the Domino to see the A1 on 15khz? Finally, after a lot of playing around, found that the AV1 output must be set to VIDEO, then the Domino can see the A1 in interlaced mode on 15khz and 32khz when the A1 is in progressive.
    Why does the AV1 output have an impact on the component output? Is this something to do with the RGB circuits?
    All is working now and looking damn fine. :devil:
    Ian.
  2. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +192
    I think it actually mentions in the manual somewhere that you can't have RGB selected at the same time. The 3800 is the same.
    I assume that at least part of the same circuitry is used, would make sense as they are essentially very similar.
  3. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    yeah its not a problem my toshiba does it as well, it is a pain if u loose pic while in menu etc.
    but nothings wrong. good choice on PJ
