Denon 770SD AV receiver and DVD player
Discussion in 'AV Receivers & Amplifiers' started by DOCTOR FURBY, Jul 19, 2004.
Tags:
  1. DOCTOR FURBY
    DOCTOR FURBY
    Jul 18, 2004
    I am buying my first home cinema surround system and was
    considering the Denon 770SD AV receiver and DVD player with
    Castle Compact speakers.
    My room size is 20ft by 14ft and I will be using the system
    mostly for movies (rather than music). A friend has suggested
    that the 770SD system is a little limited as it is 6.1 and does
    not suport formats like THX. Before taking the plunge, I would
    be grateful for some advice.
    Should I be looking at the Denon 2805 or Pioneer VSX AX3 and
    if so which DVD player should I consider as an alternative to the
    770SD. I am not too concerned about how the DVD player plays
    music CDs, more the quality of the audio and picture on movies.
  2. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    THX is not a format...
    For what you want may be a fine option.
