Denon 5803 and multi zone issues
fraalan
I have a Denon 5803 and finally got some decent in wall speakers for my bedroom for Zone 2.
I adjusted the setup to have the amp power zone 2 instead of a 7.1 configuration. but here is the kicker.
I do not have the original remote, so I have no way to turn up the volume.
I do have a logitech harmony 890 but do not see any function in the software for zone 2 volume.
I thank anyone that can offer some help.
Alan
PSM1
Zone 2 volume uses the same volume control as zone 1 (the same button). You just need to select zone 2 (so should be a zone 2 button on the remote). Most amps you have to select zone 2 and then the volume control will control the volume in zone 2.
PSM1
Since you have a logitech I would contact Logitech customer support with your issue. I suspect they do have the Zone 2 buttons encoded somewhere, just you can not find them. I have had a few issues with finding certain items and they have always come up trumps.
Crustyloafer
Denon Zone 2 Volume Up:
0000 006D 0020 0000 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0672 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 0046 000A 0672
Denon Zone 2 Volume Down:
0000 006D 0020 0000 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0673 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 0046 000A 0673
Now follow these instructions to add these commands to your remote:
http://www.avforums.com/forums/remo...ronto-hex-codes-into-your-harmony-remote.html
fraalan
as I am sitting on hold (for 30 mins) with logitech i pulled up my thread.
I can't wait to go home and try it out.
And yes I have a life, too much of one actually.
Thank you, I have a good feeling it will work.
alan
fraalan
One last issue, is there any way to toggle the multi zone 2 on and off?
I read the manual and don't see any way to do it.
I can toggle through all of the inputs for zone 2 to essentially turn it on and off, but it will take 6-7 toggles to turn it back on again or back to source respectively.
Thanks again for all the help, it sounds great!
Alan
Crustyloafer
Alan
Try these:
Multi Zone-2/3 Off
0000 006D 0020 0000 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 0046 000A 0046 000A 0046 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0673 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 0046 000A 0046 000A 0673
Multi Zone-2/3 On
0000 006D 0020 0000 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 0046 000A 0046 000A 0046 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0673 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 0046 000A 0046 000A 0673
Crustyloafer
Here are a few more that might be of use to you:
Zone 2 DBS/SAT
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 001E 000A 0046 000A 001E 000A 0046 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2 DVD
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 0046 000A 0046 000A 0046 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2 Tape-1
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2 TV
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2 VCR-2
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2 VCR-3
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2/Multi CD
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2/Multi Phono
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2/Multi Tape2
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 001E 000A 0046 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2/Multi Tuner
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2/Multi V. Aux
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2/Multi VCR-1
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2/Multi VDP
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2/3 Vol- 0dB
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2/3 Vol- -20dB
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0046 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
Zone 2/3 Vol- -40dB
0000 006D 0020 0000 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 0046 000A 001E 000A 001E 000A 0673 000A 001E 000A 001E 000A 0046 000A 0046 000A 001E 000A 0046 000A 001E 000A 0046 000A 0046 000A 0046 000A 001E 000A 0046 000A 001E 000A 0046 000A 0046 000A 0673
fraalan
The main volume was shut off and nothing would turn it back on.
I powered the unit off and it worked again, I haven't been able to recreate it.
Is there a "Zone 2/source" function available?
fraalan
just like selecting zone2/tv you select zone2/source.
It is one of the options that you scroll through.
Crustyloafer
I don't see any codes listed as Zone2/Source in the database I have. Can you confirm it is a Denon 5803 or in fact a 5308?
What does the Zone2/Source function that you are looking for actually do that none of the discreet Zone 2 source selection commands that I have already listed do not do?
