Denon 550SD....red wine in my amp remote!!
Discussion in 'Home Cinema Buying & Building' started by duckson, Mar 11, 2005.
  1. duckson
    duckson
    Nov 26, 2004
    732
    28
    Preston
    +30
    My 9 month old son knocked a table over which ended up spilling a load of red wine on my 550SD amp remote. :oops:
    Cleaned it up but theres wine inside the remote and it doesnt work at all when i try it (no LED lighting, so its not some of the buttons that are dodgy).
    I'm going to leave it overnight next to the boiler to dry it out but incase its knackered where can i get another one from?
    Is Denon direct my only hope? Anyone any ideas how much a replacement would be?! The model number on the front is RC-964.
  2. duckson
    duckson
    Nov 26, 2004
    732
    28
    Preston
    +30
    Panic over....looks like the drying out session worked as its working again, :smashin:
  3. Conn
    Conn
    Jan 2, 2005
    2,075
    +170
    If it happens again, you could always try pouring white wine on it. Should cancel out the red :D
