Denon 550 or 770
Discussion in 'Home Cinema Buying & Building' started by shaunflynn, Jan 24, 2005.
  1. shaunflynn
    shaunflynn
    With http://www.tottenhamcourtroaddirect.co.uk selling the 770 at 599 can anyone tell me the difference between the 770 and the 550 as the 550 is only 50 quid cheaper than this is it worth opting for the 770?
    Shaun
  2. nathanhill69
    nathanhill69
    Oct 5, 2004
    392
    +19
    The 550 replaced the 770, which is discontinued. I think the 770 might have had a few more input/output options on the back, although the 550's connectivity is excellent. You might find the 550 has more decoding options such as Dolby PLIIx?
  3. shaunflynn
    shaunflynn
    Thanks Nathan, I thought it would be something like that!
    Strange that the 550 should replace the 770! I would have thought looking at the numbers it would have been the other way round!
