Denon 550 cables
Discussion in 'Home Cinema Buying & Building' started by White Rhino, Jan 22, 2005.
  1. White Rhino
    White Rhino
    Just about to order a 550 and I have read elsewhere on the forum that Denon supply all the gubbins to get up and running with the xception of the connection to the TV.
    I am little mystified by all the different types of cables available - can anyone advise me on the best way to connect to my TV? I'm assuming that a good quality SCART is the answer. If so, does anyone have any recommendations for particular cables and the cheapest place to get hold of them. I am looking at a QED P21 PERFORMANCE cable from Superfi for £27 - does that sound about right?
    Thanks in advance.
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    I take it that you don't have component inputs on your TV. If not, then scart will be the best way. Buy an astonishing good quality scart from www.tvcables.co.uk for £5.99. Flat cable, gold terminals and a nice metal body. £5.99!!
    Jimmy
  3. duckson
    duckson
    Nov 26, 2004
    684
    28
    Preston
    +30
  4. White Rhino
    White Rhino
    Thanks for your help guys.
