Denon 500sd speaker stands
Discussion in 'Home Cinema Buying & Building' started by aberdeenlad, Mar 8, 2005.
  1. aberdeenlad
    aberdeenlad
    Hey Folks
    Im looking for speaker stands for my DHT500SD, does anyone know if you get stands that look good and fit these speakers perfectly. Any help would be greatly appreciated.
    Mark
  2. nathanhill69
    nathanhill69
    Oct 5, 2004
    392
    +19
    If you do a search on Denon 500 speakers stands you will find several previous threads extensively discussing this very thing.
    Nathan
  3. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Denon produce a stand called the SS30.
  4. kismet110
    kismet110
    Feb 6, 2005
    2,364
    London, UK
    +389
    As nathanhill69 suggested, do a search and you'll get the info you need but I will add that Maplins do some speaker stands in black or silver for £15.00 a pair that are compatible with these speakers and considerably cheaper than the 'official' ones.
    ALI
  5. aberdeenlad
    aberdeenlad
    Cheers folks
