Denon 500SD Settings
Discussion in 'Home Cinema Buying & Building' started by Bleeders, Jun 2, 2005.
  1. Bleeders
    Bleeders
    Jan 16, 2003
    1,051
    Grays, Essex
    +46
    Hooked this up yesterday, haven't had time to tinker around with it as such, but I did the quick setup for a medium-sized room - is it advisable to tweak the speakers somewhat or does this preset do an adequate enough job?
    I find myself having to ramp it up to get it loud, but I imagine playing with the dbs would probably cure this.
    Just interested to see what settings that some of you guys are using?
  2. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    I would only check in the system setup to see if the speakers are set to Small and the crossover to 150. I would only play further if you start to get lipsync and other such problems.
  3. Bleeders
    Bleeders
    Jan 16, 2003
    1,051
    Grays, Essex
    +46
    Thanks for that.
    The current settings are fine as they, just wondered if tinkering would help it that much more.
  4. SkyJawa
    SkyJawa
    Sep 26, 2004
    193
    +3
  5. Bleeders
    Bleeders
    Jan 16, 2003
    1,051
    Grays, Essex
    +46
    Ta' fella
