Denon 500SD or 550SD?
Discussion in 'Home Cinema Buying & Building' started by clowner, Aug 17, 2005.
  1. clowner
    clowner
    Anyone know if the 550 is worth the extra when compared to the 500?
  2. ziggy66
    ziggy66
    Aug 17, 2005
    28
    I'd love to be able to tell you but as far as I can tell the 500 is out of stock everywhere!
  3. Helterskelter
    Helterskelter
    Not sure about being 'worth more', it would 'appear' to be worth more as the dvd and A/V tuner amp are seperate and you have the added bonus of a self powered bass unit. Other than that I cant see a difference.
    eddie
  4. nicknackynoo
    nicknackynoo
    I was originally attracted to the 500 afetr reading a review then noticed they did a 550 with seperate amp. I've always believed a seperately powered sub woofer is preferable to the passive ones as the amp has less to do so no overheating or need for noisy fans.
    I opted for the 550 and it's great, I got a good price on the net but after trying to get hold of the 6th speaker for 6.1, I was told DENON are no longer supplying internet sellers, by the firm that sold me it!
    So it was worth buying at £530 but the high street go upwards of £700 so I wouldn't have bought then.
    The others are right about seperates being better, I had the DVD player go wrong on my last All-in-one and couldn't get another compatable one as it had to have the right speaker connections, have a decoder etc.
  5. a5ian300zx
    a5ian300zx
    Jun 14, 2005
    2,852
    North London
    +229
    the + for the 550 for me was.
    Pros:
    seperate amp = the is connected to the dvd player via optical Only meaning you can use any dvd player with it that was a major pro for me.
    extra speaker slot at back for the rear surround 6th speaker.
    Active Sub -100w active sub (you can connect another sub to the active sub)
    Overall the sound quality is great with lots of depth, I love the 5/6 channel stereo mode.
    dvd player (multi region) is perfect with a cystal clear PQ.
  6. sigh
    sigh
    I was origonally atracted to the 500 as well and then stumbled across the 550. The company i got mine from were out of Denon speaker systems and are selling them with a Tannoy system instead (aparently better?).
    So i have never owned the 500 but i used to have the DAVS-888 Sony system .. and it blows that out of the water laughing.
    The sound quality, clarity and depth of sound is remarkable. I would reccomend anyone to buy the 550.
    If you want to hook up loads of stuff to it then the 550 has more inputs and outputs so offers a more versatile approach with 3 optical connections (PS2 sounds great in true 5.1)
    I have read some issues with noisy cooling fans on the 500 .. you should bear this in mind.
  7. spidermanalf
    spidermanalf
    Oct 25, 2002
    1,987
    63
    Wakefield
    +103
    I ordered 550sd on Sunday, discontinued now SOBBING!
