Denon 500SD Expansion
Discussion in 'Home Cinema Buying & Building' started by Apothis, Oct 28, 2004.
  1. Apothis
    Apothis
    I have the above Denon, and was thinking about adding an extra satellite for the centre back channel, for 6.1 sound. But from what I can see, its not possible to run the additional speaker, and the included passive subwoofer at the same time, necessitating the addition of an active sub as well to have 6.1 sound.
    Can anyone confirm this to be the case? Or have I missed something.
    Also, if I'm correct, and suggestions as to a reasonable active sub to partner it with. Something that will be better than the current passive one, but nothing too extravagent, given the whole system cost only £400.
    Apothis
  2. daveb975
    daveb975
    Oct 25, 2002
    4,328
    103
    London
    +368
    I have tested the MJ Acoustics Ref 100 from my main system with my DHT500, and it sounds excellent. This sub is £350, though, so may be a bit expensive for use with a £400 system.
    Why not try Denon's own active sub, which comes with the DHT550SD. This is available as a 2.1 system for £199. If you are getting one extra satellite anyway, this may be a good option - and will give you another spare.
    This has the added advantage of matching the system.
  3. Apothis
    Apothis
    Ahh, I didnt know the active sub was available in a 2.1 package like that. I dont think I've seen it before. Do you know anywhere online that carries it?
    Apothis
  4. daveb975
    daveb975
    Oct 25, 2002
    4,328
    103
    London
    +368
    I saw this online the other day for £199 when I was looking for my DHT500. Now I can't find it anywhere.
    Avland have the full 5.1 setup for £299, so they may be able to order the 2.1?
    The 2.1 system is called SYS-M51, and the sub is DSW3L.
    I will post again if I can remember where I saw it before.
  5. Apothis
    Apothis
    Ahh. Thanks for the model number, found it at unbeatable (even though they have it with a slightly different model number)
    http://www.unbeatable.co.uk/CatalogueItem_17610.html
    Out of stock atm, but worth considering. My other choice currently would be the MS premier Avant sub and satellite.
    Incidentally, for a rear centre speaker, which would be better, a normal satellite, or a front centre speaker?
    Apothis
  6. lhough20
    lhough20
    I have the 500sd and purchased an extra satalite speaker for 6.1. I use the active sub from my old surround (a philips one....don't laugh) and it sounds fine to me.
    as the denon is capable of producing 7.1....just out of interest what type of axtra amp would i need to power the extra 2 back speakers?
    thanks for any help
    Lee
