Denon 500SD - best way to connect to TV
Discussion in 'Home Cinema Buying & Building' started by KristianH, Sep 8, 2004.
  1. KristianH
    KristianH
    Just bought Denon DHT-500SD and was wondering the best way to hook it up to my TV.
    I have a telewest cable TV box which ideally I want to output in surround sound along with a new Sharp VCR.
    The denon has hundreds of I/O
    http://www.unbeatable.co.uk/resources/images/products/0027700/0027721_04_max.jpg
    The video has scart and composite I think and the TV has Scart and s-video too.
    So how do I connect the denon home cinema, telewest box and vcr to my TV so I can watch DVDs and the footie in surround sound?
    :lease: help!!
  2. tedge
    tedge
    The DHT500 has Dolby Pro Logic so you get pseudo surround sound from a stereo source such as a VCR. If the cable box has digital audio thats the best way to go, just plug it into the coaxial or optical input.
    Did you buy from unbeatable? My player is region 2 only which was a bit of a disappointment, how about you?
  3. KristianH
    KristianH
    Bought from QED-UK.com, not used it yet but I believe it is region 2 only.
    Like you I thought they were multi-region :thumbsdow
  4. Darzo
    Darzo
    Like you I've got an ADV-500SD - anyone know where to get the multi-region upgrade?
  5. sasquatch
    sasquatch
    Sep 9, 2004
    16
    3
    I can give you the firmware if you have a cd-writer to burn it. Its about 40MB, PM me if you're interested.
  6. dino07
    dino07
    Can someone please post the firmware update for the multiregion DHT-500SD.
    Not sure how this can be done through this site.
    Please advise.
  7. Conn
    Conn
    Jan 2, 2005
    2,074
    +170
    Its here - http://www.leedsdig.plus.com/
    Please, take real care with doing this - if you are not sure of what you are doing it is possible to destroy your machine.
    Trust me, I am talking from bitter experience.
  8. Conn
    Conn
    Jan 2, 2005
    2,074
    +170
  9. camBB
    camBB
    Sep 23, 2004
    211
    +8
    I can post an image of the recent CD i've used to make my 500SD multiregion if you want?
  10. dino07
    dino07
    I have an issue with the same denon
    I have it connected to SKY+ the following was
    1 SCART TV-SKY TV
    1 SCART DENON-SKY VCR
    When i put the Denon to DVD everything works fine i.e. picture and sound
    However, when i put the Denon to TV i get sound but no picture.
    As soon as i turn off the Denon i get the picture back on the TV.
    Did have a old surround sound previously and the same connections worked great.
    HELP PLEASE
