Denon 500 & Progressive Scan
Discussion in 'Home Cinema Buying & Building' started by Gordon WT, May 20, 2005.
  1. Gordon WT
    Gordon WT
    Dec 12, 2002
    151
    Inverness
    +8
    I have the Denon connected to a Panasonic PD50 with component cables but Progressive Scan is not being detected.
    Is the Denon PS capable and, if so, how do you turn it on?
    Gordon
  2. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    Yes it's definitely progressive scan. There's a button on the front panel of the unit which you push to switch between progressive and interlaced.
    Failing that, you could always RTM ;)
  3. Gordon WT
    Gordon WT
    Dec 12, 2002
    151
    Inverness
    +8
    Thanks for that Judders........I never noticed the button.....I've only had it for 6 months :suicide:
    Auto prog scan works a treat now :clap:
    Gordon
  4. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    6 months! lol
    You're welcome :thumbsup:
