Folks,
At present I’m running a Denon 3300 running a Dali opticon 5.1 set up, and bi amping the fronts.
I want an atmos set up and I want to keep bi amping in the future , so both of these amps are on my shortlist
At present I’m well aware of the hdmi 2.1 issue of last year and as I own a series x Xbox, I’m not clear at present if Denon have subsequently changed the chip they now use and the Yamaha is pending a future firmware update, so either way i want to be sure whatever was the problem, won’t be an issue
I plan to buy the Dali phantom speakers just to keep within the same brand/same sound, and honestly think (to my ears at least) the current set up sounds great.
I know there is a price difference between the 2, so the question is the Yamaha worth the extra over the Denon?
Thanks Jamie
Thanks Jamie
