Denon 4400 Height 1/Height 2 - Where to wire top front/top rear?
Discussion in 'AV Receivers & Amplifiers' started by Harkon321, Jun 21, 2018.
  1. Harkon321
    Harkon321
    Jun 6, 2012
    1,548
    +333
    Really quick connection. Wiring up my Denon 4400 as we speak.
    Want to wire the speakers before turning it on due to access so haven't gone through the set up yet.
    Do you wire top front atmos to the height 1 and then top rear to height 2 or vice versa?
    Many thanks in advance, if anyone can answer it.
  2. Nayfne
    Nayfne
    Feb 3, 2013
    4,497
    5
    3
    north east
    +10,206
    You going for 5.1.4?
  3. CaPo
    CaPo
    Dec 11, 2005
    927
    43
    Glasgow
    +176
    Try page 52 of the manual.
  4. Harkon321
    Harkon321
    Jun 6, 2012
    1,548
    +333
    Thx sorted now. Decided to just plug in power and hdmi and have a look first.
  5. Dolus
    Dolus
    Apr 26, 2005
    554
    46
    Gosport
    +158
    If you use the Setup Assistant it will take you through the whole process of connecting and configuring your speakers.
    Setup/Setup Assistant/Speaker Setup
