Denon 4306 to Onkyo 905
Discussion in 'AV Receivers & Amplifiers' started by dUnKle, Jan 16, 2008.
Tags:
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,896
    +2,892
    Just how big an upgrade can I expect
    My sources are nearly all High Def
    Will be PS3 and HDA1 via HDMI - blu ray and hd-dvd
    Also have two outputs via HDMI (which I belive the Onkyo can do)
    So worthwhile upgrade ?
  2. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
    The specs are one part of the story the more important part for me would be the sound. The Onkyo has a different sound characteristic compared to the Denon (and the ugly blue ring with a green display but this is very personal taste of course).
    I think you should go for a demo.
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,896
    +2,892
    The Denon though (as I understand it) does not make full use of the high def sound formats
  4. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
    Unless you input via analog of course.
    What I meant: Denons have a quite warm sound and the Onkyos, Sonys etc sound different. I think you should give it a test drive befor you decide?
