Denon 3910(Prog Scan)
Discussion in 'Blu-ray & DVD Players & Recorders' started by say1, Jun 19, 2005.
  1. say1
    say1
    Sep 8, 2004
    105
    I have a 3910 with firmware version of :-
    ESS 6609-5
    DSP 6770
    SYSTEM 6767-5
    DRV 030825
    C 20041028
    MARK DAY 831
    When I use component interconnect ,PROGRESSIVE Signal can't be output but with scart connection can get prog Signal.
    Is this normal?
    Any help/Advice would be appreciated
  2. Selfar
    Selfar
    The progressive signal is output via HDMI/DVI connections and the component output. No progressive scan is output Via Scart. Check your display! is it capable of handling progressive scan or not. I have the same problem with my main display.
  3. say1
    say1
    Sep 8, 2004
    105
    I have a panasonic 42'' pw5 plasma which is capable of handling progressive scan.
  4. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    You can get a latter firmware for your machine, check with the guys you bought it from.
