Denon 3910 problem?
Discussion in 'Blu-ray & DVD Players & Recorders' started by windymillers, Sep 21, 2007.
  1. windymillers
    windymillers
    Sep 21, 2007
    2,887
    83
    Plymouth
    +246
    I have the denon 3910 dvd player which I have converted to multi region using the cd method.
    I did this about 3 years ago when the player first came out.
    Is there a more up to date multi region disc I can use on my player as for some reason, a number of newer R1 films look like they have the RCE still working as the picture goes dark, blurry, etc.:(
    Any ideas?:lease:
  2. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
    :confused:...
    Denon players are usually made multi-region using a couple of keystrokes on the remote and not firmware hacks. I suggest to apply a current original firmware and use the following procedure. In the unlikely case it will ot work (sometimes you have to repeat the procedure a few times) you still may go back to the firmware flash aka CD method.
    To make the Denon DVD-2910, 3910 and A1XV play DVDs from all regions:
    1. Ensure there is no disc in the player.
    2. Power off using the front panel On/Off button (not standby).
    3. Press and hold Open/Close, Play and Skip Reverse (I<<).
    4. Keep the above buttons held and Power-up the player using the On/Off button, holding the above buttons until the player's name disappears from the front panel.
    5. Wait until the player finishes LOADING and the front panel of the player shows 0:00:00.
    6. On the remote handset, press in sequence; 7 3 1 9 4 6 2 8
    7. The unit should enter standby mode. On the front panel of the player, press the Standby button to turn the player back on.
    8. To confirm the update, press on the front panel Stop and Skip Forward (>>I). The front panel should briefly display “Region_Ax” where x is the original region number. If not, then repeat the process 1-7 above.
    Good luck
