Denon 3910 New Firmware?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Demon00, Dec 6, 2004.
  1. Demon00
    Demon00
    Hi..
    Just got my 3910 regionfree... I saw that the firmware were made in Sep -04.
    Isnt it about time they came out with a new one soon since It seems like there are some issues with this player?
    Number one on my list is the fix for the Underscan problem with the DVI/HDMI connection.. hate that I wont get the picture as it supposed to be.. :mad:
    Yesterday I tried with a NTSC Superbit disc and then it were just perfect 720P picture with absolutly NO under/overscan later I tried the Cristina Aguilera concert PAL disc and the underscan were terrible and variable from one side to the other??!!
    Is it mabye an issue with PAL material being flaged wrong or?
    I will try some more discs later to see if this troble is PAL related..
    Is there anyone that has hear any rumours about a new firmware??
    Daniel
  2. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    What´s the latest firmware for the 3910(with multi region)? The last firmware fixed and affected :
    Chroma spread for PAL
    black xxxxx3499 or lower
    silver xxxxx0599 or lower
    Picture disappears
    black xxxxx2099 or lower
    silver xxxxx0399 or lower
    White belt
    silver none”
    When I use 1080i with my infocus 5700, the picture wobbles/vibrates... anyone else have this problem?
  3. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    i think there is a new realese is Aus land and USA
    Current here is
    Ess 6609-05
    DRV-030825
    SYStem 6767-2
    DSP 6770.
    the new release in the USA is ESS 6609-06. etc
    So not sure when it will be due here
  4. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Master Gandley,
    Do you know what the new US firmware fixes? Is that the firmware I´m referring to above(which would be weird because it fixes PAL problems)?
    Is there no way of getting e-mailed notices if there are firmware updates?
  5. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Master???? steady on
    Yes i believe it does fix the chroma delay issue, and a couple of other bits but i have no idea on its availabilty.
    Denon dont much like Disscussing multiregion in the UK so its hard to find out when this debugged MR firmware release will be available. Soon i guess if the USA has it now.
    But?? :lease:
  6. Demon00
    Demon00
    Is there a new Firmware for Aus?
    Since they are using PAL we should also get the new Firmware or?
    The regioncoding shouldent mess stuff up... Just the NTSC and PAL and if the Aussis have the same system as us... Why cant we get hold of the new firmware?! :thumbsdow
    Daniel
  7. alsyu
    alsyu
    Oct 5, 2009
    Hi sir:
    I am new in this dvd player firmware upgrade, is there a place to find the upgrade procedure?
    Thanks.
    Al
