Denon 3910 - Couple of questions
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rasczak, Feb 12, 2005.
  1. Rasczak
    Rasczak
    Apr 3, 2002
    21,221
    Argyll
    +2,268
    Would appreciate a few answers on the Denon 3910:
    1) Is the Denon 3910 multi-region out of the box and can it handle RCE discs? I appreciate this may depend on Firmware version - if so are the MR firmwares available online?
    2) Can anyone recommend a good online supplier for this model that preferably offers a fast service? I have quite a few dealings with Av-Sales - but they don't seem very competitive on this model. Other than 'mass product' companies such as PRC Direct, Empire and Sound & Vision can anyone suggest a decent retailer?
    Many thanks!
  2. Andyuk911
    Andyuk911
    Sep 11, 2004
    413
    +9
    1. Out of the box,No, you need to obtain a disk to update to MR
    2. Peter Tyson, excellent service
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,221
    Argyll
    +2,268
    andyuk99,
    Many thanks for your reply. Is the disc supplied when you buy a "multi-region" version? Or can you download it and burn it to CD-R?
  4. Andyuk911
    Andyuk911
    Sep 11, 2004
    413
    +9
    When I bought my 3910 it had only just came out and the dealer(PT) sent it to me a couple of weeks later. Search these forums, there is later versions which are MR
  5. Mose
    Mose
    Dec 1, 2004
    1,629
    Aldershot
    +149
    Had quite a few problems with Peter Tyson, I would very highly recommend Creative Audio though, they were very helpful at all times!!
  6. 1ofaKind
    1ofaKind
    Dec 16, 2002
    233
    Midlands
    +4
    Hiya,
    Got mine within 2 days from avland - good price was multi region out of the box and states on their web site RCE compatible (tell me a disc that is and I can try it) - tested Return of the king R2 and a couple of R1 (5th element, monsters inc) - most of my discs are region 1 anyway.
    As mentioned creative audio are also good - you need to ring to order though unless I missed an online ordering section on their web site :eek:
    I'd recommend either as I've bought from them both before and had good service.
  7. kmb
    kmb
    Jul 1, 2001
    As 1ofaKind said, avland also delivered mine within 2 days from ordering and Yes! the player is multiregion and Yes! it does play RCE encoded discs.
  8. linnite
    linnite
    Nov 10, 2004
    699
    28
    Burscough, Lancs
    +48
    Not sure I would count Sound and Vision in the same league as big mail order shippers. Yes they have a big mail order side but also have a smallish shop with 2 dem rooms and knowledgeable staff. Plus I got my 3910 from there for £720 :cool:
  9. Rasczak
    Rasczak
    Apr 3, 2002
    21,221
    Argyll
    +2,268
    Many thanks for the replies - I ordered a multi-region 3910 from AV Land after having done several demos locally (for which I repaid their time and effort by purchasing over £200 worth of cables from the shop).
