Denon 3910 - Blocking/Freezing
Discussion in 'Blu-ray & DVD Players & Recorders' started by GliderRider, Sep 7, 2005.
  1. GliderRider
    GliderRider
    Dec 17, 2004
    119
    16
    London, Middlesex
    Any idea why the 3910 starts to block or freeze on some DVD's. This is mainly with my DVD backup copies. These copies play perfectly OK on my Panny DMR E65?
    I am assuming it is because the 3910, in pursuit of quality, is simply less tolerant?
  2. ufitsy
    ufitsy
    Aug 18, 2004
    3,159
    103
    Midlands
    +327
    Assuming these are DVD-R, have you tried a different make (datawrite grey?)
    Try burning at a slower speed, for the blocking you may need to burn over 2 (single layer) disks
  3. GliderRider
    GliderRider
    Dec 17, 2004
    119
    16
    London, Middlesex
    Yes, tried different makes and this has improved. I'm splitting across two discs to avoid compression and preserve the quality. (I use a projector and can't afford any loss of quality).
    I will try burning at a slower speed and look at the datawrite grey.
