Denon 3910 Audio Options Grayed Out
Discussion in 'AV Receivers & Amplifiers' started by tanna11, Mar 19, 2005.
Tags:
  1. tanna11
    tanna11
    I have a Denon 3910 DVD player and for some reason I cannot access most of the audio options on the menu (they are grayed out). Every options except 'compression' and 'sacd filter' is grayed out. Anyone know how I can get access to those options? It happens even with no disc in the player.
  2. Tony B
    Tony B
    Oct 29, 2004
    553
    +21
    It could be that some of the options are only enabled if you have made the appropriate physical connections, e.g. Denon-Link
  3. Miniholic
    Miniholic
    Apr 26, 2001
    3,054
    The Shire
    +398
    Just had a look at mine, activating Denon Link leaves you with just the two options you describe. This will be because the Denon Link gives a direct digital connection to your amp bypassing the processing.
    If you aren't using Denon Loink, turning it off in the digital coinnection menu will restore the other audio options.
