H
HarryW
Hello Everyone,
After spending months reading threads about you views both for and against the Denon 3910 I have decided against the purchase of this DVD player. Instead I will look for a DVD players (budget up to £400) and separate CD player (budget up to £400). The idea behind this is to basically find a compromise between CD performance, DVD performance and the introduction of HD DVD players in the next couple of years. Although I spend 70% of my time with movies the negative view of the 3910 towards music has put me off.
Once the new HD DVD players arrive (at a realistic price) Ill put the old DVD player in the bedroom. Now I need some help on deciding what to buy. Please could you give my views on a decent DVD player and CD player integrating into the kit below? I have not purchased any of this kit yet but will be doing so once the AVR3806 is available. Im partially interested in the performance of the new Denon 1920. Thanks for you comments and help.
Pioneer PDP-436XDE
Denon AVR 3806
Monitor Audio RS6
Monitor Audio RS1
Monitor Audio RS LCR
Monitor Audio RS W12
Pioneer PDP-436XDE
Denon AVR 3806
Monitor Audio RS6
Monitor Audio RS1
