3sgte_power
Hi All,
currently i have my Denon 3910 connected to my Denon 3805 via a single coaxial cable.
I have set the Component Input for DVD as Video-1 and the Digital Input Assignment as Coaxial-1. Everything works fine.
However, when i want to play a CD through the Denon 3910 i have to go back into the Digital Input Assignment and change CD to use Coaxial-1, because it doesn't let me use Coaxial-1 for both CD/DVD use from the same source.
Is there a wat around this?
I will eventually be using Denon Link 3 - will i still have the same problem?
Cheers All...
Cheers All...
