Denon 3808/4308 software upgrade
Discussion in 'AV Receivers & Amplifiers' started by Getinthehole!, Jan 31, 2009.
Tags:
  1. Getinthehole!
    Getinthehole!
    Dec 9, 2007
    608
    +93
    Morning all I have just been given :smashin: the software upgrade key for my 3808 receiver.
    What changes and benefits can I expect from this in terms of performance?
    Is it easy to install? Will it reset all the functions on the receiver? Or do I just install the new firmware via the internet and rerun Audyssey a few times and off we go?
    I carried out the firmware upgarde on 2500BT no problem I am a bit more sceptical about the receiver as it all works a treat and sound fantastic at the moment.
    Maybe I am just scared of change and it all going up in smoke? :eek:
    I would appreciate your feedback.
  2. Getinthehole!
    Getinthehole!
    Dec 9, 2007
    608
    +93
    Wow 78 views and no response or opinion anyone got any thoughts ?
  3. mossym
    mossym
    Apr 5, 2006
    13,152
    Ireland
    +2,802
    is this the upgrade key for audyssey volume?
  4. Getinthehole!
    Getinthehole!
    Dec 9, 2007
    608
    +93
  5. mossym
    mossym
    Apr 5, 2006
    13,152
    Ireland
    +2,802
    read a few reports that it makes a noticable improvement. would imagine the worst that can happen is you have to run audyssey again when you are done. not much risk in at least upgrading and see if you like the improvements, can always switch them off if you don't
  6. DaveBirch
    DaveBirch
    Feb 7, 2008
    22
    3
    Manchester
    +4
    I upgraded mine lasts week, got the upgrade for £65, it was quite easy to upgrade you just need a few details mac address, serial number, upgrade ID number, to remember a few of them.
    The upgrade took about 30 mins or so, and when finished all the original setting remained.
    Make sure you run the auto room setup function to get the use of the new functions, I also downloaded the new manual in PDF format which shows the updates.
    The sound now seems to be much clearer and rich. The dynamic Room Eq is very good for late night listening (although i mainly have this turned off or set to day).
    There are a few other GUI changes and access to the audio setup via the remote "para" button does not take you to the audio setup anymore, you have to gain access to this menu via the "menu" setup GUI.
    I have not used the HDMI control as my pioneer plasma does not support this (well i dont think it does?).
    Just for interest I have just Bi-amped my front speakers using the spare back ports, and this also made a great improvement.
    Overall a worthly upgrade for only £65.
    Hope this helps.
  7. redknag
    redknag
    May 18, 2004
    310
    28
    Wickford Essex
    +36
    How did you get it for £65, I thought it was £75?
  8. mathers123
    mathers123
    Feb 1, 2008
    4
    3
  9. DaveBirch
    DaveBirch
    Feb 7, 2008
    22
    3
    Manchester
    +4
    Yes bought it from Hifix above. Free delivery well worth the upgrade.
  10. spike99
    spike99
    Aug 9, 2003
    99
    11
    Cardigan
    +3
    Its not emailed to you then, actually comes in the post?
  11. DaveBirch
    DaveBirch
    Feb 7, 2008
    22
    3
    Manchester
    +4
    Yes took about a week to come, Its been great since the upgrade, no bugs or issues yet.
  12. Dazmeister
    Dazmeister
    Jan 16, 2006
    563
    2
    Hampshire
    +62
    Comes in the form of a glorified scratch card. Seems a lot of money to spend on a scratch card but you have to remember what its function is! :D
  13. spike99
    spike99
    Aug 9, 2003
    99
    11
    Cardigan
    +3
    My scratch card came today, downloading now. I only just ran the set up a week or two back, so the dog and the wife will have to sit through that again!
  14. lynmouth16
    lynmouth16
    Apr 19, 2008
    2
    3
    Sorry if this is a stupid question, do you need to be connected to the internet to apply the update, I dont have an internet connection at the moment, so dont want to order if I can't apply.
  15. DaveBirch
    DaveBirch
    Feb 7, 2008
    22
    3
    Manchester
    +4
    Yes mate you need the internet. You could take your amp to a friends. Or try a Denon retailer to see if they would do the update in store?
  16. frankmcg
    frankmcg
    Jun 20, 2006
    63
    So any further views on whether this is worth it? £65-75 for a vague "improvement in audyssey eq" seems quite steep!
  17. encaser
    encaser
    Mar 15, 2001
    4,841
    Suffolk/Essex/Srebrenica
    +2,416
    So is the upgrade a matter of bunging it on an USB stick once downloaded from the Denon vaults?:cool::hiya:
  18. Peter Galbavy
    Peter Galbavy
    No, you buy a scratch card voucher and use this on a website along with you AVR's MAC address / serial thing and then this enables the firmware download when you next go online to check for updates directly.
