Denon 3805/Yamaha 2400 component input
Discussion in 'AV Receivers & Amplifiers' started by Maximus5, Sep 22, 2004.
Tags:
  1. Maximus5
    Maximus5
    May 23, 2004
    33
    Well the thing is Denon has 100Mhz component input while Yamaha only 60MHz. They both supposed to be HDTV ready. So what is the difference?
    Since I will probably need 3 component inputs is it better to get a Denon 3805 or wait for the Yamaha 2500 to come out (I have no idea when is this model coming out in Europe). :lease:
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,200
    2
    +3,674
    I'm not completely sure either which is one of the reasons I have decided to buy a Marantz SR8500. I know it passes HDTV and you get 4 component inputs not to mention 2 DVI ones as well :). I know that our Australian distributor has a Yamaha concession and he passes 1080i through those Yamaha's if that is any help.
