Denon 3805 w/ Digital Cable Help
Discussion in 'AV Receivers & Amplifiers' started by Jackel, Jun 15, 2005.
Tags:
  1. Jackel
    Jackel
    I have a Denon 3805 and have a Time Warner digital cable. I am using digital coax for the audio input and I get sound on the non-digital (analog) channels but have no sound in the digital and HD stations. I had it working but must of hit a button on the remote and now I cannot get any sound at all for the digital stations. Please help.
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,461
    United Kingdom
    +1,903
    Make sure the amp is set to AUTO. Sounds like you may have it set to ANALOG. Quickest way is to press the Input Mode button on the front panel next to the Headphone socket.
  3. Jackel
    Jackel
    It keep trying to set it to auto but the PCM kept showing up and this was the problem. So, I turned off the amp power and moved the digital input from coax 1 to coax 2 and turned the amp back on. Now everything is OK. The amp was probally sticking and by turning it off an on fixed this, but I moved the input just in case. Anyways its fixed. Thanks for the reply.
