Denon 3805 vs Yamaha RX-V1500 vs Pioneer VSX2014i
Discussion in 'AV Receivers & Amplifiers' started by NPM108, Dec 17, 2004.
  1. NPM108
    NPM108
    Nov 6, 2004
    109
    16
    :lease:
    Trying to decide between the above three as they are all more of less in a similar price bracket though at local prices in Malta, the Denon is £816, the Yamaha £765 and the Pioneer £820.
    Speakers I will be using this with are KEF Q7, Q9c, Q2ds in a large ish room (47m2)
    What are the general views of the guru's in here?
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,796
    London
    +1,080
    I would have thought that the Denon’s main competitors would be the Yamaha 2500 and Pioneer AX5Ai.
    Out of the 3 you mentioned, if you plan to utilise dvd-a/sacd then I would go for the Denon 3805 or Pioneer 2014i as they both have i-link.
    It depends what speakers you’re partnering them with, however for all-round ability I would go for the Denon 3805 – plus it has ‘that’ funky remote :thumbsup:
  3. NPM108
    NPM108
    Nov 6, 2004
    109
    16
    Thanks for your replay Tejstar, it seems strange I admit that given the UK RRP of the 3805 for some reason locally the price seems to be competitive. I just wanted to check whether the Denon Link is proprietory to just Denon players or not?
    Speakers I would be using are KEF Q series (Q7, Q9c, Q2ds)
    Plus points for me on the Denon are: Local Price/Performance, Funky Remote and the fact I've never owned one!!
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,796
    London
    +1,080
    As far as i know the Denon link is exclusive to Denon products. However, I imagine the next iteration will have i-link , especially since the Denon 3910 has both Denon link and i-link!
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,796
    London
    +1,080
    The Denon and Kef match would be very compatible - a good choice :thumbsup:
  6. BAN5HEE
    BAN5HEE
    Jul 26, 2004
    4,211
    Chelmsford
    +514
    I have the 2014i and it's a very nice amp. My fist one ever so I can't really compare it but very nice. I have it hooked up to my 868 with the i-Link and it makes everything a breeze. No need for seven billion other cables. I got the 2014i for £650 from http://krishav.co.uk/store/prodView.asp?idProduct=1008&idCategory=494
    Same day delivery and excellent service.
  7. NPM108
    NPM108
    Nov 6, 2004
    109
    16
    Thanks everyone for their posts and advice. :)
  8. Doctor_AB
    Doctor_AB
    Aug 30, 2003
    2,444
    48
    Buckinghamshire
    +79
    Yamaha can be had for £550.
  9. Tejstar
    Tejstar
    Dec 4, 2002
    22,796
    London
    +1,080
    Or even cheaper from Germany :clap:
