Denon 3805 - Video Switching relay, clicking very fast
Discussion in 'AV Receivers & Amplifiers' started by thudspud, Jul 18, 2005.
Tags:
  1. thudspud
    thudspud
    Mar 28, 2002
    2,390
    Sheffield
    +129
    Hello
    I have had my 3805 since september last year and it has been absolutely wonderful.
    When I switch the input to VCR-1 (Which is unused so doesn't cause me any problems whatsoever) the relay which switches inside to switch the video inputs clicks extremely rapidly constantly, I would say at about 5-10hz with a small gap every so often.
    As I don't use this input is it isn't a problem but when I come to sell it I can't sell it as fully working. It is still under warranty so can get it fixed but bought it online so will have to send it off and be without an amp (my only one) for probably a considerable amount of time.
    Does anybody know what is causing this problem and any way to fix it?
    Chris
  2. rszee
    rszee
    May 7, 2005
    194
    Kent
    +43
    Have you tried a factory reset?
    Just on the off chance!
  3. thudspud
    thudspud
    Mar 28, 2002
    2,390
    Sheffield
    +129
    Yes, no help, Having done a bit more research it is the video input 1 circuit that is faulty, video in 2 seems to be working fine and video in 3 seems to have lost one of the colours!
  4. bbasra
    bbasra
    Sep 15, 2004
    1,660
    48
    Hounslow
    +42
    Try and factory reset... that should hopefully fix it.
    i lost the colors on my xbox connected to vdp input and lost the sound on the zone 2 output.
    did a facory reset and all is fine now.
  5. spl23
    spl23
    Jan 9, 2004
    2,670
    103
    +382
    Not that I need to know this yet - my 3805 should arrive this week - but how do you perform a factory reset on one? Can't see any mention of it in the manual.
  6. thudspud
    thudspud
    Mar 28, 2002
    2,390
    Sheffield
    +129
    I have tried what it says in the manual about initailization, holding down the direct and pure direct buttons while powering the unit on via the main switch, If anybody knows of another reset method then please let me know as I have been onto Peter Tyson about it and they are fetching it for repair tomorrow.
