Denon 3805 sacd playback problems
Discussion in 'AV Receivers & Amplifiers' started by RSD123, Sep 4, 2005.
Tags:
  1. RSD123
    RSD123
    I have a newly aquired Denon AVR-3805 matched with the DVD-2910. I hooked up all 6 analog cables from the 2910 to the EXT.IN inputs on the 3805 to play SACD. Even if I engage the EXT.IN mode on the 3805 it only plays in stereo even if they're 5.1 multi-channel SACD's. Any help or suggestions would be great, thanks.
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    Obvious question, have you told the player to play the multi-channel version over a stereo version?
    I've got a couple that have both options and my 3910 plays the 2 channel mix first, so I have to stop it then choose the 5.1 version (as did my Sony and Pioneer players before that).
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    The remote has a SACD setup button. It allows you to select how to treat an SACD via the on screen display. If you select 'multi' it will play the multichannel mix first.
  4. RSD123
    RSD123
    Thanks, but I've tried all those options. Like another post I read here I think it may have something to do with the audio menu options (which are all grayed out). I'll just keep trying things until something rectifies the problem. :)
  5. Cwhelan
    Cwhelan
    Jan 29, 2005
    141
    16
    Milton Keynes
    Have you setup the correct input source on your 3805? to recieve via the 5.1 RCA rather than 2RCA / firewire / Denon Link etc...?? :confused:
  6. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Make sure you have no disc in the 2910 when you go into the setup menu.
  7. RSD123
    RSD123
    Thanks guys
  8. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Have you fixed it? What was it? :confused:
