Denon 3805 remote woes
Discussion in 'AV Receivers & Amplifiers' started by freeranger, Oct 25, 2004.
Tags:
  1. freeranger
    freeranger
    I've only had my amp for a few days, and I've had a few problems with the remote, eg:
    - It hangs and I have to remove and replace the batteries
    -On a learned device, some of the keys when pressed, seem to cause the remote to reset itself - it goes momentarily blank, then returns to the Amp device where, say I was an DVD or something when I pressed the key.
    - Some codes it just does not want to learn (eg the standby button from a TiVo remote)
    has anyone else experienced similar problems?
    thanks
  2. freeranger
    freeranger
    Guess it's just men then :(
  3. HappyLad
    HappyLad
    Quite a few people, me included, have had problems with the 3805 remote.
    Get a fresh set of batteries and see if your problems continue.
    If you still have problems then I'd get your dealer to order a replacement.
    I've had a replacement after some of the keys refused to light on mine.
  4. freeranger
    freeranger
    thanks happy, I'll try that.
    Don't normally have to bin the batteries with a remote straight away though...
