Denon 3805 remote problems.
Discussion in 'AV Receivers & Amplifiers' started by JIT, Jul 6, 2004.
Tags:
  1. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    I do actually like this remote although there are plenty of people who don't but last week the borders on both the top and bottom parts of the remote disappeared along with the on/off at the top of the screen. All of the other buttons remain lit except for the these and last night it wouldn't operate my freeview box using DBS as source but maybe it has just forgotten these commands so i'll try again tonight.
    Anybody else experienced this or anything else?
  2. Wij
    Wij
    Nov 17, 2003
    1,151
    Northants
    +52
    That happens to mine when the batteries are running low which is fairly often as this remote eats batteries like you wouldnt believe!
    Try some brand new batteries see if the borders,on/off come back,if not then obviously its another fault but I'll put my money on batteries.
    Sean
  3. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    I'll try a new set, just thought i'd get more than 2 1/2 weeks out of the batteries supplied.
  4. ahh
    ahh
    Oct 13, 2003
    84
    London
    This happened to me as well with the 3805 remote. I complained to Denon and they asked me to return it. But, before I could do anything about it, the remote came back.
    I did put in new batteries, but am not sure if that is what helped... :confused:
  5. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    A new set of batteries brought it back to life, hopefully these last a bit longer.
  6. jamesl01
    jamesl01
    Mar 13, 2004
    206
    28
    Birmingham
    +61
    I have the same problem with my remote. Time for yet another set of batteries.
  7. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
    What's the verdict on the 3805?
    I am about to upgrade my home system from a Sony STR-DB940 and 32" Wega TV to Denon 3805, 30" Sharp LC30HV4E LCD and Infocus SP5700 with 7' electric screen.
    Any comments on the improvement I should hear/see?
  8. jamesl01
    jamesl01
    Mar 13, 2004
    206
    28
    Birmingham
    +61
    Lee
    Do a search on 3805. There is plenty of user feedback about what owners think. Personally speaking I am really pleased with it.
    James
  9. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    I'm also pleased with mine after upgrading from a 1803.
    Perhaps a set of rechargeable AAA's might be needed if the remote continues to use batteries at this rate.
