Denon 3805 Q&A
D
DaveP
I thought it might be an idea to have this thread as a means to solving new owners problems.
Here is mine:
When playing back a stereo source (ST:Enterprise in this case) I don't get any output from the sub. This happens with DPLIIx and Ne06 as well as 7 Channel stereo.
The speaker test works the sub fine as does the THX setup. A 5.1 movie also gives the sub a workout.
Am I missing soething in the setup to get my sub to work with a stereo source? It was fine with my 3802
Dave
Kazman
I find this happening on my Marantz SR7400 when the speakers are set to large. Setting the speakers to Small feeds the sub with a signal. Could be the same for the denon.
D
DaveP
Thanks, but I'm beginning to think it's a problem with the Denon. I had speakers set to small and there was zero output to the sub. I set to Large and then there was a very slight output from the sub.
I rang AVland and they seem to think it's a setting in the setup somewhere. I cannot find anything relevent though.
Dave
spike99
Have you considered the cross over frequency, if the feed is analougue from Sky, and in two channel there is probably very little if any LFE to speak of. Providing the sub cuts in in dolby Digital or the like where there is a dedicated channel and obvious need I would say this is correct. Could what you are watching just be lacking effects? Just a thought and I am no expert, but I have one of these and I am currently weighing it up.
Kazman
What about the cross over settings in the amp? It could be that the crossover is set too low? If that isn't the case, it could well be a faulty amp.
One way to test it would be to switvh to a music channel such as MTV: Bass, switch the amp to DPLIIx Music mode and see if the sub kicks in then (usually does with my setup and the previous SR4300 I had).
Kazman
Great minds think alike :):)
D
DaveP
Thanks guys but the crossover is set to 80Hz. I think it must be a problem with the receiver. I'll take it back to AVland.
The material has plaenty of bass, it was fine with the 3802
If no-one else has any suggestions I'll have a 100 mile round trip to do!
Thanks anyway
Dave
Jase
Have you checked the Channel Levels for each of those modes to see if the SW Channel is set too low or off?
D
DaveP
Originally posted by JoeKiragu
Also try a test tone to ensure that your sub is actually emmiting a tone.
Thanks anyway!
Jase, di I have to set it for each then?, I thought all that was taken care of when I ran automated setup?
Dave
CARLOS
When switched to stereo does the display on the front of the amp show two speakers and sub ?
NonPayingMember
Previously Liam @ Prog AV
DaveP - as daft as it may sound you have got the sub plugged in properely haven't you??? Certainly with Denons I'm always accidently plugging into the SUB IN on the 6ch input instead of the SUB conenction on the pre-outs, and then proceed to spend an hour playing with settings until I realise my mistake!!! Also the surround back (SB) preout is another tempting socket to try and plug the sub into
CARLOS
Ok think i may have found the answer, Fingers crossed ?
If you go into the speaker setup menu then select subwoofer mode setup and switch it to LFE + Main (as default its set to LFE only).
Hopefully that will cure it, If not i`m at a loss ?
D
DaveP
On the left of the display it shows just front left and front right. On the right of the display it shows the full 7.1 speaker system
Dave
CARLOS
Dave
In which surround mode ?
I really ment what is on the display in stereo mode ?
D
DaveP
In stereo mode the display on the right shows FL, FR & SW. On the left it is just FL & FR. There is no sub output in Stereo mode.
A question for you: When you did the Auto Setup did it put your levels at around +10db? I'm thinking maybe I should adjust them all back down to a reletive 0db? (Some would be + 1 or 2 and others -1 or 2)
Dave
D
DaveP
Thanks Carlos, that is only an option if I set the speakers to large all round. With the 3802 I had them set to small. Even when using LFE + Main I still only get a low level of bass from the sub, barely audible.
I can run like that by upping the volume on the sub.
Dave
CARLOS
Dave
I think it did set them up arround the 0db mark will check tonight.
Having to up the volume on the sub still isn`t right, You may have a faulty amp :(
Jase
Jase, do I have to set it for each then?, I thought all that was taken care of when I ran automated setup?
The Denon's will store independent Channel Level settings for each mode. Once you have set the Master Levels in the main setup menu (the Auto Setup should take care of that) you can then adjust each mode to your taste. If the 3805 has a Status Button, press that whilst in each mode and you can cycle through various settings and see what the Channel Levels are.
Just one thing, set all speakers to small, all bass to the sub first. Just to doublecheck that it's all working as it should be.:)
logiclee
Carlos
I have fell foul of this with my 3803. You can set the levels up in the main configuration but if they are turned down in a specific mode the amp will remember this.
I have my main speakers set to large as they are big floorstanders (Sound a lot better in Large than trying to split the bass with the sub). In Stereo I have the sub at a lowish level but in Direct and Pure Direct I have the Sub off. In Dolby/DTS I have the Sub higher.
I took LFE+Main to mean any Bass sent to the Sub would also be sent to the Main speakers. I found this to muddy the bass somewhat in my setup so I have left it set at LFE only.
Edited to add...........
What does seem strange is that in stereo I'd have thought no Bass would be sent to the Sub as the FL & FR speakers are set to Large but there is still bass sent to the sub unless the sub is set to off.
Lee
D
DaveP
Well I fixed it now and boy what a difference:clap:
I had nothing to lose so I reset the micro-processor and voila! a nice thumping bass
Thanks to everyone for their suggestions, I appreciate the help you get off this forum:smashin:
Dave
Ridcully
Can the remote full control a Sky+ box. I see in the manual there is the usually 'it may not work with non-Denon equipment' but wondered if anyone had actually tried it.
chris
I just used the learn function with my denon remote and it works a treat with my sky+.
Took a bit of time to programme it all in thow.
65-inch LG C1 Review coming soon to AVForums
Latest News
Sennheiser Consumer Electronics acquired by Sonova
  • By Andy Bassett
  • Published
Freeview Play viewers get Android TV homescreen update
  • By Andy Bassett
  • Published
Hisense announces US TV and soundbar ranges for 2021
  • By Andy Bassett
  • Published
AVForums Podcast: 5th May 2021
  • By Phil Hinton
  • Published
AVForums Movies Podcast: 4th May 2021
  • By Phil Hinton
  • Published
