Denon 3805 on screen display
Discussion in 'AV Receivers & Amplifiers' started by Desticado, Oct 23, 2005.
Tags:
  1. Desticado
    Desticado
    Oct 16, 2000
    1,482
    41
    Canterbury, Kent, UK
    +6
    hi everyone.
    Im just setting up my 3805 and I cant seem to get the onscreen display up via component monitor.
    Have checked that 'pure direct' as Im aware this can cause some problems.
    Here's hoping.
  2. Desticado
    Desticado
    Oct 16, 2000
    1,482
    41
    +6
    ok, i've delved a little deeper and im not getting anything from any of hte video sources to be output via the monitor out...
    hope someone can cast me a pearl of wisdom.
  3. Jase
    Jase
    Mar 16, 2001
    10,959
    United Kingdom
    +3,421
    Check you haven't switched the Video Off via the remote.
  4. Desticado
    Desticado
    Oct 16, 2000
    1,482
    41
    +6
    Thanks Jase,
    Got there a little ahead of you in the end but you were bang on the money. :thumbsup:
    It had previously been configured for someone else so still getting to grips with all the defaults that have been changed.
    so far so good though (now I can see the display :cool: )
  5. mugsy
    mugsy
    Nov 1, 2002
    687
    Kent
    +20
    That would be me then ;) ...I was going to restore the default settings for you but didn't get round to it :suicide:
    Make sure you run the auto-setup if you are trying any of the EQ modes as they were set up for my room/speakers.
    Best regards,
    Marcus
  6. Desticado
    Desticado
    Oct 16, 2000
    1,482
    41
    +6
    no problems Marcus.
    My own fault for being impatient and presuming it was all too much like my previous Denon, but then it was 4years since I set that up so maybe I should read more of the manual... :D
