denon-3805 no sub signal in neo6 and PL IIX
Discussion in 'AV Receivers & Amplifiers' started by spylab, Jun 16, 2005.
Tags:
  1. spylab
    spylab
    May 9, 2005
    368
    Athens Greece
    +17
    I cant make my amp output signal to sub in PLIIx and NEO:6 surround modes
    in 5 /7 CH stereo there is signal to sub.Also in Dolby digital all ok.
    At the amps front display (output signal channel indicator) the subs light is on.
    Any help wellcome.
    By the way i am very happy with this amp , with 5 definitive clr 1000 speakers
    and a bw asw 675 sub, films and music is exemplary.
    tnx in advance for any help.
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,440
    United Kingdom
    +1,820
    PLIIx and NEO:6 Modes don't generate any LFE (unless you overlay PLIIx on top of a Dolby Digital or DTS 5.1 track) so to get the most out of your sub you need to set all speakers to small and route all bass to the sub.
  3. spylab
    spylab
    May 9, 2005
    368
    Athens Greece
    +17
    jase tnx for the help. :hiya:
    In the speaker set up > subwoofer mode> there is LFE and LFE+main
    in LFE+main there is sub signal with neo 6 -pl II.
    I guees in DD or DTS i will use LFE only.
    I will do some tests and post back.
    This are the speakers i use, from one original i made 6 copy
    The drivers are seas .
    got them from http://www.solen.ca/
