Denon 3805 MultiZone Problem
Discussion in 'AV Receivers & Amplifiers' started by amoore, Jul 10, 2005.
Tags:
  1. amoore
    amoore
    I don't know if I have a defective unit or if it is simply user error.
    I've got 5.1 set up and working fine for my Main Zone. I'm trying to connect two more speakers (the 3805 has 7 amplifiers) in an adjacent room. I've connected them to the last speaker posts, Surround Back/MultiZone. In System Setup, I've changed the Amplifier Assign to Zone 2 (also tried Zone 3). I've used the Zone 2/3/Rec Select button to assign the CD to both Zone 2 and 3. Unfortunately, I get no audio to the speakers. I do get audio to the Main Zone if I select CD for its input.
    Any ideas of what I might be doing wrong?
    Thanks in advance.
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,443
    United Kingdom
    +1,821
    The 3805 won't output a digital source to Zone 2 so you'll need to connect up a pair of phono cables from your CD/DVD player and use it's analogue output.
  3. spl23
    spl23
    Jan 9, 2004
    2,671
    103
    +382
    You also need to make sure you have the volume for the remote zone turned up - the manual is very unclear on this! Set the remote to "Zone 2" or "Zone 3" and adjust the volume - the default is -infinity dB, so you get no sound.
    I have to say about Denon - products very good, but manuals absolutely atrocious!
