Denon 3805 input channel indicator
Discussion in 'AV Receivers & Amplifiers' started by hooch, May 11, 2005.
Tags:
  1. hooch
    hooch
    I recently got my 3805, and I was surprised that input channel indicator on the left part of the display does not show up at all for stereo sources like CDs.
    Can anyone confirm that it's OK?
    I checked 2805 and it always shows number of input channels for all sources.
  2. shodan
    shodan
    Dec 11, 2001
    10,119
    shoeburyness
    +4,405
    I think I've experienced that too. I think it's something to do with whether or not the stereo signal is digital or analogue and / if it is carried to the amp by digital or analogue (bitstream or PCM).
  3. hooch
    hooch
    Well, I tried playing a CD thorugh my DVD player connected to optical input, and MP3 files ripped off CD through my computer connected to coaxial input - same thing. It supposed to show FL and FR channels, but shows nothing.
    2805 - does.
    Does that indicate a possible problem with my receiver?
  4. hooch
    hooch
    Either my question is not clear or nobody has 3805 receiver. :)
    Let me put it in a more clear way:
    when I play a DVD movie recorded in Dolby Digital, I see 5-7 channels on the left side of the receiver's display. When I play a CD, I do not see 2 channels for some reason. My DVD player is connected via optical cable, I tried coaxial too.
    My question is what is the reason for that?
    :lease:
  5. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +181
    I might be able to answer you with my 2805 later this evening, does the display show PCM when it's playing?
  6. hooch
    hooch
    Yes it does. Display shows "DIG" and "PCM".
    I know that 2805 shows 2 input channels for stereo, I had a chance to play with it.
    But it's really weird that 3805 does not do that. :confused:
