Denon 3805 & Banana Plugs
Discussion in 'AV Receivers & Amplifiers' started by 1ofaKind, Mar 14, 2005.
Tags:
  1. 1ofaKind
    1ofaKind
    Dec 16, 2002
    233
    Midlands
    +4
    I have just swapped out my old 3802 for a 3805. However when I came to put the speaker cables in (all have banana plugs on) they would not fit!!
    Now unless I'm missing something is there a different size of plug that needs to be used with the 3805 or is it bare wire only.
    I could not see anything in the manual or anything obvious on the connectors to enable my standard banana plugs to fit.
    Any thoughts?
  2. fama
    fama
    Jan 28, 2002
    142
    most amps come with the speaker terminals
    blocked off in some way either completely or
    partially,you will normally find a small plastic lug that
    can be prised out,or in yamaha's case a small plastic ring
    to be prised out,I would imagine denon to be similar
  3. adrianl
    adrianl
    Met this problem with 2805 but easily solved by looking back over forum!
    Get a woodscrew (No 8 size works nicely) and screw it in a little way into the plug in the socket (because it's a tube-shaped plug in a normal banana-sized hole - apparently put in to meet some EC regulation so it can't be confused with a French mains socket!).
    Once screw 'bites', keep the the clockwise pressure on it, and you'll find you can pull it out easily. Once you've practiced with one you'll have the others out in seconds.
    A bit naughty of Denon that the manual doesn't mention this, nor could I find any supplement unless I missed it.
  4. BLS
    BLS
    I've finally bought some surround back speakers and was once again irritated by trying to get the wire in the binding posts on my 3805.
    Luckily I found this post and discovered I had some No.8 screws knocking around - Fantastic! Cheers adrianl
    I'm now off to buy some banana plugs.
  5. boulders
    boulders
    Jan 1, 2006
    537
    46
    Chicago
    +128
    Thanks Adrian, first hit on Google saved me, I was about to remove my banana plugs!:thumbsup:
  6. sunnyb4u
    sunnyb4u
    hi there i have tried to remove all the plastic from the inside of the banana post caps from my yamaha rx-v359 and i cant see the metal barrel which hold the metal banana plug i can only see the metal point at the fat end of the connector
    have they removed this metal barrel or do i have to keep removing the plastic?
    i may have a bad feeling that i took too much plastic off
