Denon 3805 and Multi-Zone Help
Discussion in 'AV Receivers & Amplifiers' started by sorensent, Dec 24, 2004.
Tags:
  1. sorensent
    sorensent
    I have a pair of bookshelf speakers that I'd like to listen to in the next room and am wondering how I should go about doing this. The signal to the bookshelf speakers seems just fine as they work in the "Surround Back" configuration. I need help getting the binding posts to work as a Zone 2 output.
    TIA,
    Todd
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Todd - doesn't it have instructions in the manual? Although I know the Denon manuals aren't the most user friendly ones out there!
    There's quite a few Denon 3805 owners out there who should be able to help, although I don't think that it's difficult to do.
  3. sorensent
    sorensent
    RTFM, I live by that being in the computer field. Well, I tried to follow the manual to the best of my ability. I thought I had the setting changed, out of the box the wire posts come setup as Back Surrounds, but no luck. :-( I see a lot of discussion on the 3805 and that's why I posted to this board.
    Thanks,
    todd
  4. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    You work with computers and RTFM... Ahh must work with windoze :)
    Sorry... stuck in the office babysitting a load of servers when I want to be wrapping up Xmas pressies.... Does strange things to a girl!!
    Ok I admit it I RTFM, ok, well I RTO'RB (read the o'reilly book) :)
    Steff
  5. S H A D O
    S H A D O
    Mar 16, 2001
    10,434
    United Kingdom
    +1,805
    You need to access the Main Setup Menu and the Power Amp Assignment feature. Change this from Surround Back to Multizone/Room. The rest you'll have to get from the manual as it's been ages since I tried this on my old 3801! LOL.
    Just bear in mind you lose Dolby EX/DTS ES etc capability so you can only have 5.1 in the main room.
  6. sorensent
    sorensent
    I just don't get it. I'm doing what Jase listed already but still nothing. I'll check connections and hopefully get things done soon.
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Make sure your speakers are connected properly and the polarity is right. If that doesn't work maybe something is busted? :confused:
  8. sorensent
    sorensent
    I got the info on another board. You need to turn the Zone 2 volume up independently of the main volume via the remote. By default it's set a -70db, not a great listening level. :) Thanks for the input!
    Cheers,
    Todd
  9. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Nice one Todd - glad you figured it out :smashin:
