Denon 3805 and how to connect Philips Wireless Sender
Discussion in 'AV Receivers & Amplifiers' started by bbasra, Nov 23, 2004.
Tags:
  1. bbasra
    bbasra
    Sep 15, 2004
    1,660
    48
    Hounslow
    +42
    Hi, i have just bought my Denon 3805 and want to set it up.
    Before i can do this, i have one issue..... my Philips Wireless TV/Video Sender. How can i connect this up to the Denon and be able to watch and change the channels from my bedroom.
    The philips has 4 Scarts inputs and 1 scart output which currently connects into my plasma and all my dvd, sky, and xbox connects to the scarts.
    The reason, i want to use the Denon for my video as well as the sound is for the OSD which makes it a lot easier to use, otherwise i would just leave the video side of things how they currently are configured.
    Bal
  2. Flimber
    Flimber
    Sep 22, 2002
    13,671
    Yorkshire
    +4,476
    AFAICS, just connect the sender to the "Room 2" outlets via a scart to 3-phono cable (composite video + stereo audio) and ensure it can 'see' any equipment you need to control. Then any source selected as "Room 2" will show upstairs on the reciever. Voilá.
    HTH,
    Mike.
