Denon 3805-a Disappointment
Discussion in 'AV Receivers & Amplifiers' started by turbospud, Jan 4, 2005.
Tags:
  1. turbospud
    turbospud
    Jun 6, 2004
    55
    Recently replaced my sony strdb940 with the denon 3805 added the extra 2 speakers mission cinema 7s package,2 extra m77s and what dissapointment where the sony was vibrant and punchy the sound from denon is a strangled muted sound ,the volume has to be lifted to 2/3s to give any resonable performance,i set it up using the auto feature microphone with no problems any help as to where ive gone wrong or is the denon just overrated,it has some nice features like component switching but if it cant produce the sound compared to the sony its not worth keeping,any suggestions appriecated
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    How long have you had it and how much use has it had?
  3. Family Guy
    Family Guy
    You need to put the eq setting on "Front". I found the 3805 to be dull & lifeless until I did this. Carry out this small adjustment and stand back... :thumbsup:
  4. recruit
    recruit
    I would try setting it up manually with an SPL meter to re-adjust the levels of each speaker...
    John
  5. simonn5
    simonn5
    Nov 4, 2004
    62
    Highbury
    I have also recently purchased this amp and initially had the same view as you but have now tweaked the settings and the sound is fine - maybe still a touch smooth and rich compared to my old Pioneer VSX1011 but far better than the sound achieved just using the auto set up.
    As Family Guy says try using the different eq settings - I found Front to work best with music.
    Also make sure you set the crossover BEFORE starting auto set up and play around with the cross over - I have now settled on 100hz instead of the default of 80.
    I'm hoping the sound will open up even more once the unit has been run in for a while but even now this amp beats my old Pioneer in every department - just don't expect it to ever sound bright!
  6. EN
    EN
    Jul 24, 2000
    267
    19
    Sofia, Bulgaria
    My opinion is the same comparing SONY 5000ES to DENON 3905 the second sounds without punch and powerless.
  7. Rolo Tomasi
    Rolo Tomasi
    Dec 13, 2002
    215
    +4
    I, too, used to have the STR-DB940 and got the upgrade itch. Whilst I'm better off music wise with the HK set-up I now have, I am certain that the movies side is no better and maybe not as good, which is hard to admit having spent a considerable amount of money!
  8. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Agree with Family Guy and Recruit- first switch off ALL the hocuspocus, take your time setting the ting up and go from there.
    It should sound much better than the Sony.
    Barend
  9. normsplace
    normsplace
    Feb 1, 2004
    15
    after reading all of the above, i am really stuck on deciding what to get, i am about to upgrade my sony strdb2000 and i'm looking for a good amp to match my denon 2900 and kef 5005's, my shortlist is the denon 3805 as i believe this would be a good match with my dvd or a pioneer vsx ax5ai-s.
    Any suggestions? :lease:
  10. SpudGunMan
    SpudGunMan
    well first i want to say that i dont ever trust the little "auto set up microphone" ever
    trust your ear not the mic
    that is your problem turn off the auto **** and run it under preset settings or set your own.
    i am running a 1905 and bypassing all the internal DSP except for the 7.1 decoding and running all into my pro audio equipment. - I pulled out my old Onk for this new unit and it sounds just as good.
  11. Tejstar
    Tejstar
    Dec 4, 2002
    22,813
    London
    +1,082
    Very true. I use the auto setup as a guide only. I felt that my amp only truly came 'alive' once I'd manually tweaked the settings.
  12. Repo
    Repo
    Jul 21, 2004
    430
    Sheffield, UK.
    +21
    • All kit needs time to run in. My set up sounds a lot better now after about 100 hours of use than it did when I first set it up.
    • Do you have decent interconnect & speaker cables? Expecting a £1,000 amp to sound great with bundled leads is expecting too much!
    • Check for any silly mistakes. One day I found that my last bout of tweaking had resulted in me accidentally switching the sub off & I couldn't figure out why the sound quality had deteriorated so much until I spotted it :zonked:
    Having said all of that, I'm still not totally satisfied with the sound quality either but I've still got a few cables to upgrade and playing about to do. My setup is currently too bass heavy and lacks sparkle. It's a shame that the auto calibration doesn't work as well as it could, that was one of the reasons why I chose this amp!
  13. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    When setting up my 2500 the mic set the rears to quiet i think. At -1.5 you couldn't hear them at all at +3.5 the surround effect is much better now, can actualy hear the rears and they are not over powering.
  14. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    NO auto setup is perfect by a long shot. I go over mine with a SPL meter everytime I use auto setup and adjust the crossovers back from 110 to 80 etc.
    I think what your missing is your Sony 'in-your-face' sound that the Denon doesnt do. This is all the more reason to DEMO, DEMO, DEMO.
    :lesson:
    Why isnt the Yamaha 2400/2500 on peoples short list? I would say its more like the Sony style wise but a million miles better Ok so no funky (fragile, unreliable) remote but all the rest of the bells and whistles with superb stereo ability and THX certification to boot:smashin:
  15. Family Guy
    Family Guy
    I stick by my original answer...switch the equaliser to "front" and stand well back...you could end up on your arse, I guarantee the difference will be that big... :thumbsup:
  16. turbospud
    turbospud
    Jun 6, 2004
    55
    the denon is a straight swap for the sony, same everything,ive tried altering some of the settings in manual mode it still lacks compared to the sony,it has gold plated connections the denon doesnt ,says something about the manufactures intentions,if i hadnt had the sony first i would of in ignorance thought the denon was quite good,but the reviews it has had are false, anyone have a list of manual settings that they think improves its output to try before i consign it to the cupboard
  17. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I also agree:D I did it with my 1400 and it made quite a difference :smashin:
  18. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Dont do that swap/trade it for a Yamaha 2500 :devil::D:clap:
  19. Family Guy
    Family Guy
    Turbospud - where do you live? I think you may have a faulty unit...the Denon 3805 I lived with for 4 months (I'm a custom installer by trade) blew the socks off everything else I heard in 2004 in it's price range...including my current Onkyo 702, which is THX certified.
    BTW, I'm offering to come round and check and maybe tweak your amp, FOC, if you live within 20 miles of me...(Epsom, Surrey...)
  20. turbospud
    turbospud
    Jun 6, 2004
    55
    family guy that answer cheered me up,better put the cushions on the floor behind me
  21. turbospud
    turbospud
    Jun 6, 2004
    55
    unfortunatly in scotland
  22. Family Guy
    Family Guy
    That's a shame - though I wasn't joking about putting the equaliser on front...if you read the review in HCC (www.homecinemachoice.com) and search for it in the reviews section, you'll see the reviewer reccommended that as well...
    All due respect to sony, but this should make your Sony sound like a transistor redio brought from e bay for a pound... :thumbsup:
    If you're thinking of getting rid, I'll swap you one for one for my 1 month old Onkyo 702 in silver... ;) - specs here
  23. turbospud
    turbospud
    Jun 6, 2004
    55
    ill have a play with that and see if i can get better results
  24. Family Guy
    Family Guy
    I'm sure you will...the auto setup on the Denon is the best I have used - bar none. The one on the Onkyo is a complete waste of time. I've told Onkyo this but they told me to :rtfm: !! I'm a custom installer!!! I don't need manuals!!!
    For what it's worth, The Onkyo auto set up might as well not be there - it's that bad... :thumbsdow
  25. saeav
    saeav
    Dec 10, 2002
    Having today had a demo between a Denon 3805 and Yamaha 1500 I have to say I preferred the sound of the Yamaha. The Yamaha, to my ears definitely seemed to have more sparkle and clearer dialogue (the word 'bright' is often bandied about but I think lots of people might view this as a negative term).
    Dfour is absolutely right - Demo, demo demo and trust your own ears. I went into the demo with my mind pretty well set on the Denon (I have a denon dvd) but walked out with the Yamaha.
  26. turbospud
    turbospud
    Jun 6, 2004
    55
    set the eq curve to front and fell forward,the levels are less, sounds better in normal,must be something else or as other people are saying the denon doesnt do it,also the demo of an amp in the shops is totally different when you get it home,thats where you rely on reviews and forums like this
  27. turbospud
    turbospud
    Jun 6, 2004
    55
    have tried all the different settings, lifting the db levels,making speakers large or small in different combinations,altered all the eq settings and it still sounds strangled and dull,reinstalled the sony and what a differance, movies come alive,the bass can be felt through the floor again, this one knocks you on your arse and only using 1/3 of available volume,the denon has to be at-25db[whats the number thing all about you would think it would be actual volume number, it only goes to +5db top wack and even then not testing the speakers] so could it be a faulty amp or is the strdb940 a cracker,its only been in use 2 months
  28. Family Guy
    Family Guy
    The volume settings are - ref level. So, listening at -25db, you are listening at 25 decibels below ref level (which is normally 75db...). The +5db is the maximum level and is 5 decibels above ref level...
    My distant conclusion would be that you have a faulty amp. During the time that I had this amp (about 4 months), I watched Spiderman 2 at -10 and my daughter (who sleeps directly above the front speaker soundstage) swore blind she felt her bed raise of the floor, such was the sound pressure...
    Mind you, I was running it with Miller & Kreisel speakers and a REL sub...what speakers are you using?
  29. turbospud
    turbospud
    Jun 6, 2004
    55
    mission m77 series cinema 7 package,paradigam sub,if i think its a faulty amp,do you think av sales will send another one or do you need someone to cheak it first
  30. Family Guy
    Family Guy
    I have no idea mate, I've never dealt with them. No harm in giving them a ring though...
