Denon 3803
armxz02
Ok, quick question....
Whats the best way to get the on screen display from my Denon 3803 to the Panasonic AE500 projector?
Use a 10 metre normal Video cable or 10 meter S-Video cable?
Which is better?
Opinions please....
laurie
Well if it's just for setting up just use composite video a single 10m cable is far cheaper than a 10m S-Video cable my .02 worth
cheers laurie
armxz02
Thanks laurie
The video cable seems to be the best choice.
Where can I get a 10 metre component video cable from?
:rolleyes:
Stereo Steve
If you just want this for the OSD, don't get a component cable, get a COMPOSITE one. It'll have an RCA plug on each end, a component cable has 3 and will be hugely more expensive. Have a look on Ebay for a long subwoofer cable or something with phonos each end, it'll be fine. I got mine for a fiver.
If you want to actually pass video signals from a DVD player or similar through the amp to the PJ then you want either an Svideo or component cable as composite will not be too hot.
