Denon 3803 vs Yammy AX750SE
Discussion in 'AV Receivers & Amplifiers' started by coldrobba, Mar 3, 2005.
Tags:
  1. coldrobba
    coldrobba
    Mar 3, 2005
    185
    London
    +3
    Hi Guys,
    I have read on here for a long time, but now its time to post!
    Any way i have been offered a Denon 3803 for £400 from a freind but i was thinking of getting a Yammy AX750SE , Now i'm stuck which one do you think would be the better buy or performance?
  2. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    400 seems a bit steep for the 3803, offer him 350 and see what he says :)
    All in all, the 3803 will have better amps than the 750, but the Yamaha will have more features. Personally, I'd choose the 3803.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    23,016
    London
    +1,152
    The 750SE doesn't have a tuner if that's important to you.
    On the other hand if you're looking to go 7-channel, the Denon 3803 does not support Dolby Pro-Logic IIx.
  4. Grimley
    Grimley
    Sep 19, 2003
    1,013
    4
    2
    67
    Deepest, Darkest Essex, so BEWARE!
    +185
    If it were me I'd get the 3803, I wouldn't use the PLIIx... :lesson:
  5. morksbeanbag
    morksbeanbag
    Jul 25, 2004
    723
    Chesterfield, Derbyshire.
    +49
    i agree. the 3803 will be better overall. 400 isn't bad. if he won't go down then pay him more.....so to speak.
  6. Resonance
    Resonance
    Jan 31, 2005
    268
    +17
    I'd go for the Yamaha.
    Couple of years ago I did a home trial of Denon (I forget which model, but it cost about £750) and Yamaha and I found the Yamaha gave a much better surround sound - particularly PLII and Neo:6. I also found the Denon sounded rather flat for music and the bass recessed. In DD or DTS the Denon improved, but the Yamaha was still better - more exciting and it enveloped me in sound better.
    I was a bit suprised at the time as WHF was raving about the Denon. Maybe the Denon was smoother - but I thought it dull.
