Denon 3803 upconverting
Discussion in 'AV Receivers & Amplifiers' started by nhk, Feb 1, 2003.
Tags:
  1. nhk
    nhk
    Dec 30, 2002
    82
    I have a question:
    Does this feature do away with the need to by a JS Box to convert RGB to component?
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    No, because the 3803 will only upconvert S-Video to Component or Composite to S-Video. It has no RGB connections/inputs.
  3. nhk
    nhk
    Dec 30, 2002
    82
    Sorry me being unclear.
    I have Sky (Grundig) that has S-Video out connector. This means I can send it to the 3803 and get component to the Plasma.
    The alternative was to take RGB from the Sky (scart) through JS Box to component and then to 3803.
    I don't have the 3803 yet, but it seems that it saves me £150 already.
    Unless the upconvert is not as good as JS Box.
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    That´s the only question mark as I can´t compare the two.
    At least you can take the S-Video out of your Sky box, to the Denon, upconvert to Component and then onto the plasma. So thats good news.:)
  5. EvilMudge
    EvilMudge
    The upconversion just takes the S-Video signal and converts the chrominance part to U&V. The JS Box does colour space conversion from RGB to YUV - it should be much higher quality than the upconverted S-Video signal.
    HTH
  6. shoestring25
    shoestring25
    Feb 2, 2003
    3,838
    essex
    +411
    never heard of the 3803 before commig on this forum it explains why the 3802 is suddenly cheaper now.
    what is the difference between the denon 3802 and the new 3803?
    cheers:)
  7. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    Have a look HERE and scroll down to the 3803.
    Main differences are new Processor (Super Sharc), Dual DAC´s on each channel, Video Upconversion, DTS 96/24, Master Audio Delay (cures lip-sync), Pure Direct Mode (uses 4 DAC´s per channel for music playback).
  8. DJP
    DJP
    Jan 10, 2003
    74
    Hampshire, UK
    +5
    For those interested in buying one, Leading Edge Concepts have gold ones in stock at £749 - well at least they did this morning when I ordered mine. :D
    Derek
  9. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    in that web site, it says: Audio Delay adjustment to match audio signals with video signals(0-200ms). Does that mean you can adjust the audio in either direction, or can you only delay the audio? What if the lip sync is because the audio processing is taking longer than the video processing, or does that never occur?
    Taimur
  10. DJP
    DJP
    Jan 10, 2003
    74
    Hampshire, UK
    +5
    I'll let you know for sure tomorrow but AFAIK it can only add delay. It may be possible to reduce the delay by changing the speaker distances.
    Most of the time additional delay is required due to the added video processing in Plasma's etc.
    Derek
  11. SimonD
    SimonD
    Dec 24, 2002
    134
    16
    Basingstoke
    Denon are not doing themselves any favours these days...
    I got an e-mail today from Denon stating that the only model in their lineup which does video-upsampling is the AVC-A1SR.
  12. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    You can only delay the audio from 0 to 200ms in 1ms increments.
  13. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    thanks for the information. Are there any amplifiers that allow both audio and video delay, or is a silly question as it's invariably the video processing delay that causes lip sync problems with things like PAL progressive scan?
    Taimur
  14. EvilMudge
    EvilMudge
    Don't think there are any audio components that allow you to adjust the delay of the video side, since it's normally the video side that needs the audio delayed to match it. There are some scalers where you can adjust the amount of processing and thus alter the delay time on the video side, but I can't see this as a common or useful feature.
  15. nhk
    nhk
    Dec 30, 2002
    82
    According to Hayden Labs, 3803 still not arrived. What are these guys up to that it takes so long to get the products to the UK.
    Surprised that LE Concepts selling the 3803 (is this UK sourced?).
  16. uncle eric
    uncle eric
    Absolutely and I have to say the quality of the John Sims product is quite superb. Unlike other products, John uses broadcast quality components. Like many others in the custom install business, I use only JS boxes in my installations.
  17. nhk
    nhk
    Dec 30, 2002
    82
    Thanks Eric for that explanation.
  18. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    now that we have RGB to YUV upconversion, which negates the need for component output on a DVD player, does anyone think there will be a future black box to convert interlaced video to progressive scan output?
    Taimur
  19. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    RGB to Y-Pb-Pr is transcoding across to maintain image quality, that picture should remain the same.
    There are plenty of boxes that will de-interlace video signals or various types.
    The most heard of are the Iscan range, but there are many about from £250 upwards that will do a reasonable job. Though obviously you pay for what you get.
    Component outputs on DVD players save you having to use a transcoder, they'll continue to appear in increasing numbers.
  20. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    Oh well, now that I have all this information about component upsampling and deinterlacing, I think I'm back to wanting to buy the Linn classik movie system.
    Linn, Gallos and Panasonic Plasma sounds like it'll look good, produce good video and sound good (in that order!). I'm starting to save....
    Taimur
  21. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Make sure you get the next version of the Classik (whenever it will be) that can do surround sound processing of external sources.
  22. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    Thanks for the advice - the man in the Linn shop in Glasgow was telling me that there might be a new one coming out in the next few months. I see also that many shops are now beginning to discount the classik movie system and it's on sale for around £1500 in a couple of places - I've always seen this as a sign of imminent replacement!
    Taimur
  23. TimF
    TimF
    Just a quick note to say that I got my 3803 today from Leconcepts.
    Sounds good, and video upsampling and master audio delay works a treat - simplified my set up somewhat!
    Timbo
  24. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Yep, the video upsampling on my A1SR works a dream. Not only does it make connections easier (though I still have S-Vid connections from all video sources and an S-Vid to pj - quess I didn't believe it :zonked: ) but I noa also no longer have the dreaded chroma bug on Sky sources.
    Previously the red Sky active dot (yuk!) was actually one and a half dots (or blobs) but is now a single blob. Don't ask me how but Sky never looked this good previously. I have all my sources (inc Sky) feeding into the A1SR and component out to my Quadscan in turn conneceted to the pj via VGA to 5 x BNC (4 used).
    Oh, and it also means I nlonger have to switch to an S-Video input on the pj to get the Amp menu screens and onscreen graphics. Double bonus.
    Absolutely cracking. What an amp :smashin: Uncle Eric, I think you are gonna be mighty pleased when yours turns up :D
  25. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    ...and then someone posts a message like this and makes me want to go down the separates route again!
    Taimur
  26. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
