Apologies for the inconvenience, but AVForums will be down from 6am Thursday 21st January 2021 for quite some time while we perform a major update to our core software. See what changes are coming.
Really struggling at the moment to get the on screen display up to set the amp up,exactly which connection on the back of the amp do i connect into the tuner the tuner box on my plasma?
you need to use a composite or s-video lead from monitor out on the 3803 will not show on screen menu over component.
make sure you are plugging monitor cable into right hole on back of 3803 . when i moved mine round i spent a few hours trying to figure out why it would not work. there is so many connenctions its easy to get it wrong.
i use a cheap composite into plasma. remembe to select the imput its going into on plasma too. mine is on av.
As far as I know the 3803 will display the OSD via component. My old 2802 didn't but I'm pretty sure the 3803 will, otherwise it would be pointless having composite or s-video upconversion as you'd still always need to have a comp/s-video connection to use the OSD.
did not know that. dont know where i got that info then, i dont use the 3803 for any video so i only have the composite monitor out plugged into iscan.
