Denon 3803 - Initial setup question
Discussion in 'AV Receivers & Amplifiers' started by woody123, Nov 26, 2003.
Tags:
  1. woody123
    woody123
    Jun 30, 2003
    65
    Chelmsford
    Finally took the plunge and bought a Denon 3803 and although I've not been able to set the unit up as I'm waiting for a component cable to arrive it sounds Ok. Not quite a punchy as my old Yammy 795a but I guess that's just tinkering with the setup.
    A quick question if I may, will it be possible for the wife to be able to switch between TV & DVD & Xbox (not that she ever uses it) just by pressing one button on the remote. Or will she have to press the AMP button then TV?
    James
  2. Jase
    Jase
    Mar 16, 2001
    9,407
    South Coast
    +856
    Once the remote is set to AMP, just press the DVD, CD, TV button for whatever you want. You don't have to press AMP first between each selection. :)
